Hi B&O world,
I would like to connect a Beosound encore to 4 beolab 6000 speakers. As the speaker are located at different edges of the room, 2 of them are currently wired connected to the Beosound (Powerlink daisy chained). For the 2 other speakers , I would like to use 2 beolab receivers with a Beolab transmitter 1.
Here is my question : can I daisy chained the beolab transmitter with the 2 beolab which are connected to the Beosound Encore. In other term, the B&O input in the transmitter will come directly from the power link out of the beolab 6000 speaker. Is there going to be a lag between wired and non-wired speakers ?
Thank you for your help
Best
Elliot
Thank you Lawrence. Is there another way to prevent this ?
