I have a few questions to ask but I’m going to start with the beocenter 4000.
How do I replace the display bulbs?
i don’t want to order new ones without first removing the old ones but I, not sure how they come out.
i can get to them alright, just feels like I’m going to break something when I try to remove them.
They are soldered in.I can supply new lamps.
Ah, well. That makes sense, then. I may be ok for bulbs but will let you know. thanks for your help.
