Beogram 8000 Power not working?
Frederikp
Posts 10
Frederikp Posted: Fri, Aug 14 2020 7:18 PM
I finally got speakers. I recently had a post about a Beogram 8000 with a cable that I needed. Now, for whatever reason it doesn't power up when I put the plug in the socket.. How screwed am I?
Frederikp
Posts 10
Frederikp replied on Fri, Aug 14 2020 9:18 PM
At some point it just decided to die. Did I do something wrong?
Frederikp
Posts 10
Keith
Shrewsbury
Posts 138
Keith replied on Fri, Aug 14 2020 10:46 PM
Check the fuse in the power unit.
Frederikp
Posts 10
Frederikp replied on Sat, Aug 15 2020 7:36 AM
I'm very bad with technology, how exactly do I do that?
Keith
Shrewsbury
Posts 138
Keith replied on Sat, Aug 15 2020 9:50 PM
Lift the right cover and from the under side, push up and out the power pack, you can then lift off the top cover of the power pack and inside you will find the fuse.
sonavor
Texas, United States
Posts 3,732
sonavor replied on Sun, Aug 16 2020 3:50 AM
If you hadn't messed with the inside of the Beogram and it blew a fuse then I would expect the problem to remain. It is worth a try to change the fuse but it isn't something B&O expected a Beogram 8000 customer to have to do. It isn't mentioned in the user manual so if you are not comfortable with technical type things like that then I would hire a technician to do it.
-sonavor
Page 1 of 1 (7 items) | RSS
