I would like to clean the inside screen of my beovision 7
Which product can I use ?
Any help or advise welcome
Ken
About the only thing that won't cause streaks when wiping the anti-glare screen is the steam from your own breath and a very clean microfiber cloth. If your screen is really dirty, this can take a long time.
I once had a girlfriend who saw no buttons on my TV and assumed the screen was touch sensitive like an iPad. I must have spent several hours cleaning her fingerprints off my BV7-55 screen. What a mess!
BeoLab 5, BeoVision 7-55 MK2, BeoSound 5 Encore, BeoSound 9000, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, BeoLab 7-6, BeoSound 8, BeoTime (analog clock), Beo 4 remote.
Thanks for the reply Hungedu, but I have a problem with dust on the INSIDE of the screen.
I guess I have to take the TV to bits to get at the inside of the screen, but wont to know how to clean it so I dont get any marks.
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
JKW TAYLOR: Thanks for the reply Hungedu, but I have a problem with dust on the INSIDE of the screen.
Take off the backpanel. Then at both sides you will see screws with a spring. Unscrew these. Then lift the glaspanel for a centimeter and take it towards yourself.
With the mk1 and 2 you have screws on the left and right side.
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
The best thing to clean the screen itself in window/glass cleaner in my experience. Also try removing the screen like others have suggested, it worked for me.
A damp cloth (water, plus a little dish detergent) works well too, but you need a dry cloth to hand (or several dry cloths).
Wipe with the damp cloth first, then quickly buff with the dry cloth. I find it easiest to clean a small area at a time.
The water in my area is very soft, so this may not work so well if you have a lot of dissolved minerals in your water.
Thanks for the tips. You can always learn from Beoworld.
