Smartphone app
This post has 9 Replies | 3 Followers
Griebel
Posts 416
Griebel Posted: Mon, Jan 14 2013 9:40 PM
Hi Folks,
Used Plugplayer, Twonky, eLyric etc with my iPhone to connect to BeoMaster 5 without any problem for a long time until my BM5 went to repair.
Once back and fully working the apps no longer see the BM5 on the local network.
A real mystery to me as the BM5 seems to be configured correctly (Music Server is selected, BM5 is on the same network as the iPhone). Reinstalled the app, but it didn't help.
Anyone a clue on what happened and how to solve the problem?
Thanks.
BeoJunkie
Posts 16
BeoJunkie replied on Sun, Feb 17 2013 4:05 PM
Audio master settings?
Griebel
Posts 416
Griebel replied on Sun, Feb 17 2013 8:18 PM
Audio master setting is YES.
Barry Santini
New York
Posts 543
Make sure your BM5 is registered with Bon, and cd ur PC to ensure the BM5 shows as a shared folder BMSHARE$.
Griebel
Posts 416
Griebel replied on Tue, Feb 19 2013 6:30 AM
BM5 is registered with Bonjour and it shows as shared folder BM-SHARE$.
Audio Master is set to YES and both iPhone and BM5 are on the same network.
I really don't get it. Worked fine previously and now doesn't anymore.
Anything to do with iPhone iOS update from 5 to 6?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Feb 19 2013 7:55 PM
See in the set-up of the BM5 if It has a serial number.
No serial no updates.
missing updates can be the cause of your problem
Griebel
Posts 416
Everything seems fine with the serial number and update (see picture attached).
Thought I knew everything with the system, but there is one piece of the puzzle missing.
Stan
Chicago-area USA
Posts 869
Stan replied on Fri, Feb 22 2013 3:46 AM
Maybe the IP address has changed, and the iPhone app has the old one cached?
Stan
Chicago-area USA
Posts 869
Sorry duplicate
Griebel
Posts 416
Griebel replied on Fri, Feb 22 2013 7:49 PM
Tried 2 iPhones, one of them had never been used to connect to BM5. So the IP is not the cause.
Doublechecked the BM5 parameters. Cannot find anything wrong.
Some (as yet) unidentified thing is prevented the BM5 to communicate with the smartphones, while both are on the same wifi network
Page 1 of 1 (10 items) | RSS
