hi,all,i'm new guy here
how can i connect my beosound moment to beovison harmony and use the tv's speakers? the both devices are in the same network. now i can only use the multi-room function, the harmony tv can join the moment. thanks
If you first JOIN the moment, you can then program a My button to select this source directly in the future. Not quite full product integration but close.
I tend to recommend the BeoRemote One BT version without Netflix / Amazon buttons in this scenario as it has 4 my buttons rather than one.
thank you very much, now i know it's not my device's problem ,hope b&o can reconsider TV's speakers link with moment
Fansastic:Hi, unfortunately it is not possible to connect the Moment to the Harmony / Eclipse and use the (attached) speakers of the TV. Only work around is the join function on TV when Moment is playing a source. Also the Moment will not show up as a source on the TV, so you cannot start a session on the Moment directly from TV. You must first start the Moment and then join the TV. Also there are no presets for sound/speaker groups for the source through Multiroom, so you need to adjust this manually on Horizon also. This also leads to non functional sound adjustment on the Moment. As there are no speakers connected, you need the remote / app to adjust sound levels on whatever is playing. All this was possible until the LG TV’s (Harmony / Eclipse). I do not think there is a fix for this on the road map, very disappointing and it is one thing on my wish list. Maybe, just maybe B&O will reconsider this as they have shown new love recently for the Multiroom / NL protocol on the Balance.
Eclipse 65V1-32Beosound M5Essence MK2BLI
Seanie_230:Hi there That is a great shame actually, so you don’t get product feedback from the moment on the screen like you do with the avant 55? BLGW - Rekindling the love of ML
thank you,now i'm in the same way as you used, program a MY button to join the moment's multi-room, but still hope B&O can fix the BUG
riverstyx: If you first JOIN the moment, you can then program a My button to select this source directly in the future. Not quite full product integration but close. I tend to recommend the BeoRemote One BT version without Netflix / Amazon buttons in this scenario as it has 4 my buttons rather than one.
