BeoLink Converter 1611 - Audio extremely silent
This post has 11 Replies | 0 Followers
Tim84
Munich
Posts 98
Tim84 Posted: Wed, Aug 26 2020 8:37 PM
Hallo,
I have a BeoVision 7 in my Office and wanted to send Audio from my Mobile to the BeoVision without turning it on. So I thought I could use my old BeoLink Converter 1611 (sw1.3) and connect an Aux cable to it and then connect my iPhone to it.
in General ist works  Bit the Audio sent from the Converter to the BV is extremely silent and los volume. Is there a was that the Converter sende a higher volume?
Living room: BeoVision 7 MKV + BeoLab 7-2 + 2x BeoLab 8000 + BeoLab 2 + 2x BeoLab 4000
Office / guest room: BV 7-32 MKIV / BL7-1; BeoSound Core + Turntable
Kitchen: BeoPlay M3
Bathroom: Gira Radio + BeoLab Celestial
Entrance: BeoPlay M3
lawrencejmcook
Posts 742
Hi Tim84,
iPhones have quite low output. You may find that you need to set the volume to at least 75% to get decent output.
If you have an old Airport Express hanging around, you’ll find that it has a much higher output level, and you can then send music from your phone wirelessly.
Lawrence
Tim84
Munich
Posts 98
Tim84 replied on Thu, Aug 27 2020 5:38 AM
lawrencejmcook:
Hi Tim84,
Lawrence
hi Lawrence,
even when i try to connect a Beosound core the volume is so low that i have t set the volume of the to to Max to hear something. Am i doing something wrong or does it have to work in general? I use a five pin aux cable that works perfect on my ouverture.
Kitchen: BeoPlay M3
lawrencejmcook
Posts 742
Tim84:
hi Lawrence,
Current System
Livingroom: BeoVision 7 MKV + BL7-2 + 2xBL 8000 + BL 2 + 2x BL 4000; BeoSound Ouverture Bedroom: BV 7-32 MKIV / BL7-1 Kitchen: BeoPlay M3 Bathroom: BeoPlay M3 Entrance: BeoPlay M3
Hi Tim,
Indeed, there may be something wrong with your 1611. I’m afraid I’m not technical enough to advise further on that.
The fact that the cable works between the Core and the Ouverture’s (Aux?) input suggests that it is fine.
The last thing I can suggest: when you connect the Core to the 1611’s Aux input, configure the Core to give a fixed level output from its Powerlink sockets. If the menu options allow, configure this to be as loud as possible.
If you can’t find this configuration option, again, turn up the volume on the Core to somewhere near the maximum (at least 75%).
Good luck, sir.
Lawrence
Millemissen
Flensborg, Denmark
Posts 14,680
Tim84:
Hallo,
I am not quite sure how you have connected things?
Assuming you want to use the 1611 as a masterlink driver, you also must have it connected to the BV with a Masterlink cable.
Iin this case you must turn on the BV in order to hear anything from the speakers/BV7.
However,  you write that you don’t want to turn on the tv!
Also activating the converter would require the BV.
Please bring some more details.
Tim84
Munich
Posts 98
Tim84 replied on Thu, Aug 27 2020 10:25 AM
Millemissen:
Tim84:
Hallo,
Hi Millemissen,
the Converter 1611 is connected via masterlnk to the TV. The Core is at the moment connected to the 1611 via a 5 pin Din aux to RJ45 cable. When I press Music on Beoremote One the TV turns on, activates the Loudspeaker but the display stays offline (that is what I want). But the sound coming from the TV is super silent and remindes me of the sound from a vinyl player when you have no pre amp.
Kitchen: BeoPlay M3
stefan
200 miles from Struer
Posts 2,920
stefan replied on Thu, Aug 27 2020 11:03 AM
For me it sounds like wiring is connected output to output.
BLC 1611 has in and outputs on the AUDIO AUX LINK (7pin DIN) socket.
A simple way to test that, would be, to connect a 5 pin DIN - 4x rca adapter, connect the phone via mini jack -2x rca cable, and test the 4 different rca connections.
Hope this helps
Stefan
Tim84
Munich
Posts 98
Tim84 replied on Thu, Aug 27 2020 12:31 PM
Is the AUX Link Port any different from the one from Beosound Ouverture?
I tried 5 different cables with my Beosound Overture and all work perfect but when I connect them to the BLC the audio is too quiet. I mean at full volume of the TV it is a whisper.
Btw. all cables are from steve so superb quality.Do I have to change something in the BLC? Is there a way to reset or program it new?
Kitchen: BeoPlay M3
RaMaBo
near Munich
Posts 626
RaMaBo replied on Thu, Aug 27 2020 12:45 PM
is the TV connected via masterlink to the other rooms?
if so there's already an audiomaster in the ML network: The Ouverture! There can only be one audiomaster in a ML Network.
The BLC 1611 can only work as an audio source to your BV7 in the Office if the Office ML is not connected to the remaining ML network.
Ralph-Marcus
Tim84
Munich
Posts 98
Tim84 replied on Thu, Aug 27 2020 12:51 PM
The TV is not connected to the Masterlink in the Livingroom. There is onlyy a connection between the Beovision and the 1611.
Kitchen: BeoPlay M3
RaMaBo
near Munich
Posts 626
RaMaBo replied on Thu, Aug 27 2020 1:55 PM
Okay, so i would do what Stefan said. Try a 5pin DIN to 4 RCA adapter.
Ralph-Marcus
Tim84
Munich
Posts 98
Tim84 replied on Sun, Aug 30 2020 7:58 PM
Ok i was in munich  this Weekend and had the Chance to get a 5pin DIN - 4 Cinch Adapter from my parents. I have to say Stefan was right. This adapter works.
Does the Aux Link have a different pinset than the Aux Connection on the Beosound Ouverture?
Kitchen: BeoPlay M3
Page 1 of 1 (12 items) | RSS
