I have had a beovision 32” Avant from new in 2000. I have used it with both sky box and more recently a virgin TVIO box both with Scart, however I recently got the new Virgin V6 box that has no scart and only HDMI,
I eventually bought a new smart TV but now want to use the 32" Avant with a iVeiw HD box that has a scart connector but can’t get the TV to see the STB i have tried to change the input on the tv setup / connections menu. Both the AV STB (V.AUX) and the Decoder STB (SAT) menus offer a long list of STB models but no mention of iView, i am not very 'techy' so any advice would be warmly welcomed.
many thanks
Chris M
You will not find an iView in the STB list because in the original AVANT they were physical chips which defined the set top boxes it could control. B&O stop producing updated STB chips for the AVANT years ago and you can see the last available HERE
Later B&O TV's had PUC's which could be updated.
Your best option is to find out what IR (Infra-red) protocol is used and use a box with the same protocol which will give you at least the basic commands
Regards Keith....
