Possible to Export PUC codes from BV11
kimhav
Malmo, Sweden
Posts 314
kimhav Posted: Thu, Aug 27 2020 6:34 PM
As subject indicate; is it possible to export/dump PUC codes from an existing BV11 (or V1)?
Seanie_230
UK
Posts 2,278
Seanie_230 replied on Thu, Aug 27 2020 10:25 PM
Export for what reason?
You can delete your PUC from the TV
If using another NL TV you just download them to the new TV
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Sat, Aug 29 2020 9:39 AM
Primary reason would be to explore and create your own PUC files for device which isn't supported or improve the existing ones and then of course the possibility of importing to BV which doesn't have the option to download the PUC codes.
Millemissen
Flensborg, Denmark
Posts 14,680
Creating the codes should not be the biggest problem - they could be send to you from a dealer/technician.
How to get these loaded to a pre-BSys4 tv however, a bigger problem.
Page 1 of 1 (4 items) | RSS
