When I use the turntable i have to push the 33 1/3 button because it always starts on the 45 rpm speed. Is there any way to check/repair the auto speed control?
festers: When I use the turntable i have to push the 33 1/3 button because it always starts on the 45 rpm speed. Is there any way to check/repair the auto speed control?
First thing is to change the belt, a loose belt may cause the motor to "double" speed.
