Center speaker with BeoLab 5.1
This post has 13 Replies | 2 Followers
Mrankit07
Posts 6
Mrankit07 Posted: Sat, Aug 29 2020 2:41 PM
I am new to the world of B&O. I just recently bought my BeoLab 20. I am trying to create a 5.1 setup.
BeoLab 20 in front & 17 in rear. I will be using marantz 7705 and transmitter 1  To connect them to my projector Optoma Cinemax P1. I am trying to figure out which center speaker to use. I have read many threads on this forum where people have recommended 7.4/7.2/7.6. However,  Is it a good idea to use any other brand center speaker? Has anyone tried it?if yes which brand Do you recommend?
Johan
Bolsward, NL
Posts 450
Johan replied on Sun, Aug 30 2020 7:46 AM
Hello Mrankit07, welcome!
Why not a BeoLab? The 7-1s come really cheap now (with a BV7 attached to itSmile)
I also managed to collect a 5.1 system of BeoLab speakers, using a BeoLab 7-1 for center. I am really pleased with it. Be aware that the 7-1/2/6 are stereo speakers, and the 7-4 is not, it has a very different shape and an acoustic lens (as your 20s have). A more rare, but I believe more powerful BeoLab center speaker is the BeoLab10, also with the acoustic lens technology. This speaker is visually much more present than the others, but could look stunning.
Let us know what you will do!
Regards, Johan
Mrankit07
Posts 6
Mrankit07 replied on Sun, Aug 30 2020 1:12 PM
woukd having a dedicated centre speaker better than using stereo speaker?  I cannot use 7-4 as aesthetically it won’t fit in the current setup.
i was thinking of using either klipsch credit 64 iii or kef htc8001.  However, I am not sure if I am making The right decision
jowus
Posts 161
jowus replied on Mon, Aug 31 2020 3:21 AM
Hi, for 5.1, don’t you need Subwoofer as well?
Why don’t you try BeoLab 19 and 4000 as a Center? Anyway, Welcome on Board and Good Luck! Getting the Right Sound from Your Speakers, makes you go Crazy sometimes! But I trust the 17 and the 20’s!
jowus
Posts 161
jowus replied on Mon, Aug 31 2020 3:27 AM
Coming back at You! This is the Reason why, B&O, Should come back with BeoSystem 5! It’s very much Needed for Surround Sound, In stead of Proud Owners of B&O Searching out for Receivers!
beojeff
USA
Posts 2,012
beojeff replied on Mon, Aug 31 2020 10:08 AM
Not only does B&O need a BeoSystem 5, but B&O also needs to fill the absence of a center channel speaker in the current speaker selection. Does anyone else remember years ago when there as an interactive section of the B&O site where we could design a home theater and see have various configurations would look?
I have Beolab 9s as my fronts with a Beolab 10 as the center below a 3rd party 75 inch tv that can be covered with a motorized screen lowered when I want to use the projector in CINEMA mode. The Beolab 10 looks and sounds great with the Beolab 9s -- which look similar to the 20s. It's advisable when using a projector to have a dark wall where the screen is in order to avoid reflecting light. My wall is painted a dark grey, and the black Beolab 10 nearly disappears when watching movies. You can always recover the fret with fabric to match your wall if you want to.
Mrankit07
Posts 6
Mrankit07 replied on Mon, Aug 31 2020 3:11 PM
I thought with  BeoLab 20  i  could  get away using a subwoofer. Has anyone tried using a 3rd part centre speaker with b&o setup?
beojeff
USA
Posts 2,012
beojeff replied on Mon, Aug 31 2020 4:49 PM
Mrankit07:
Using a BeoSystem 4 AV processor, a subwoofer would not be used because the BeoSystem 4's bass management would redirect the LFE channel to the Beolab 20 speakers. With a 3rd party processor, however, you do not have B&O's bass management technology.
jowus
Posts 161
jowus replied on Mon, Aug 31 2020 7:31 PM
Hmm! Good to know this, BeoJeff! I just acquired Lab 19 and BeoSystem 4 to Add to my old Stuff, does that means, I didn’t even need that?
beojeff
USA
Posts 2,012
beojeff replied on Mon, Aug 31 2020 8:39 PM
jowus:
It all depends on which speakers you have. In the older version of the Technical Sound Guide, there was a great chart on the last page that showed which speakers would get re-routed bass from which subwoofers. If speakers handle the bass better than a dedicated subwoofer, those speakers get the LFE instead of the subwoofer.
lawrencejmcook
Posts 742
beojeff:
Here’s the older version of the TSG with bass management matrix:
https://bangolufsenassistentgohe.blob.core.windows.net/manuals/TELEVISIONS/BEOVISION%2011%20WITH%20BEO4/technical-sound-guide-1409%20(2).pdf
Lawrence
jowus
Posts 161
jowus replied on Tue, Sep 1 2020 3:03 AM
beojeff:
Hi BeoJeff,
The Speakers using now is BeoLab 1, Pentas and BeoLab 4000, and I’m about to hard BeoLab 19 with the System 4 just to get the 5.1 Surround Sound. I was going to go for the lab 17 and get raid of Pentas, but want to try this first!
beojeff
USA
Posts 2,012
beojeff replied on Tue, Sep 1 2020 9:58 AM
jowus:
beojeff:
Hi BeoJeff,
You will definitely need a subwoofer with the Beolab 1 speakers. The lack of bass was a huge shortcoming of the Beolab 1.
Mrankit07
Posts 6
Thanks for this information.
Another question: if I am using marantz preamp 7705 then  do I have to use center speaker with Amplifier?
 My local dealer told me that it has to be a powered center speaker if I want to use it with Marantz 7705
Page 1 of 1 (14 items) | RSS
