Beosound 3000 Not starting
This post has 4 Replies | 0 Followers
Russ Pitman
South East, UK
Posts 7
Russ Pitman Posted: Mon, Aug 31 2020 4:48 PM
Hi there,
I have recently been given a lovely looking Beosound 3000 (2672), the small clamp version.
Unfortunately it will not startup and seems to sit there with the REG and GREEN led illuminated.
I have selected SOUND, 1, STORE on my beloink 1000 and the RED LED flashes once.
The doors are working and the CD clamp works when 'LOAD' is selected. With a CD inserted it does not read the disc....
I can get into TESTMODE and TM27 returns the following:
1 MEM 2
1 ML 32
IIC OK
1 SER 5
1 CD 6
OS OK
1 IO 58
1 AP 73
1 IOP 19
The system is at:
AP 1.3
OS 12.02a
IOP 21.0
TUN X.X
CD X.X
Any pointers on what to look for next, or test?
Many Thanks
Russ
Russ Pitman
South East, UK
Posts 7
On another note, does anyone know the belt size for the door motor on this unit?Wink
Bill Briscoe
Chicago, IL USA
Posts 165
I think that when the green light is illuminated it means that a timer has been enabled.  Make sure the clock is set correctly and delete any timers.
Good luck,
Bill
Russ Pitman
South East, UK
Posts 7
OK, thanks, just tried that, unable to get into any of the TIMER options.
Russ Pitman
South East, UK
Posts 7
I have just run TM28 and that is returning MEM ++- which is pointing to an EEPROM issue....!?
Page 1 of 1 (5 items) | RSS
