V.MEM sound not showing up on 3200
This post has 4 Replies | 2 Followers
AymanG
Posts 9
AymanG Posted: Tue, Jan 15 2013 6:48 PM
Hello.
I am hoping someone can help me resolve this.
Room A: I have a BV4-65 connected to a BeoSystem 3. 5 speakers. Also connected to the BeoSystem 3 is an AppleTV (accessed as V.MEM on remote).
Room B: I have a BeoSound 3200 (with integrated speakers) which has a BeoLab 2000 as well.
The 3200 and BeoSystem are connected with MasterLink.
I am able to listen to music playing on the 3200 on the speakers in room A.
I also can listen to TV sound on the 3200.
What I can not seem to be able to do is listen to the AppleTV sound on the 3200. When I select LIST > AV > V.MEM at the 3200, what shows on the 3200 is V.Tape and no sound. Again, if I select TV at the 3200, I get TV sound but it does not seem to pipe in the V.MEM (AppleTV) sound.
I hope I have explained this well and that someone can help. Thanks for your help.
Raeuber
Germany
Posts 2,542
Raeuber replied on Tue, Jan 15 2013 7:19 PM
Hello AymanG,
you have to connect your ATV also analogue, not only via HDMI. Therefore you need a digital-to-analogue converter: optical wire from ATV to converter and two cinch cables from converter to BS 3.
Regards
Räuber
AymanG
Posts 9
AymanG replied on Tue, Jan 15 2013 9:01 PM
Thank you Räuber for you reply. The cinch cables.. where do I connect them to on the BS 3? Do I need to configure in BS 3 settings?
Thank you again.
AymanG
Raeuber
Germany
Posts 2,542
Raeuber replied on Tue, Jan 15 2013 9:15 PM
You can use a scart connection with an adapter like this:
http://www.amazon.de/mumbi-SCART-AV-Adapter-Umschalter-In-Out/dp/B003JGQFFG/ref=sr_1_1?ie=UTF8&qid=1358284407&sr=8-1
/Räuber
DoubleU
Posts 562
DoubleU replied on Wed, Jan 16 2013 7:03 AM
Why not use one of the AV-sockets without scart, but with L/R RCA sockets?
Page 1 of 1 (5 items) | RSS
