Change order of List menu for TV
This post has 3 Replies | 0 Followers
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Wed, Sep 2 2020 10:33 AM
Hello there
When I had the IR only version of the Beoremote one with my avant 55 I could change the sort order of the functions in the list for TV menu.
Since moving to the BT version the TV and MUSIC options are according to the TV setup,
BUT the list menu cannot be resorted.
is there a way to do this?
I would like my Homecontrol function to be at the top of the list.
Cheers
Sean
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Aussie Michael
Melbourne, AU
Posts 3,730
Even though it's a delayed response.
AFAIK, there is no way.
Yes, you used to be able to do this, but now with BT, it's two way and it takes the sources from the device.
You can change the order of the devices, eg; if you want BV14 to appear at the top or BeoPlay A6, but control will always be under these.
Aussie Michael
Melbourne, AU
Posts 3,730
Sean, did you ever get this sorted?
Regards
Michael.
Raeven
Posts 61
Raeven replied on Thu, Jan 20 2022 7:33 AM
I have a related question. In my list menu (TV) I have two time the same item. But in the app list of my (LG) TV only one time this ithem. Also I have under de list the item HDMI A, but have nothing connected to the HDMI A port. (the Stage is connected to a LG TV).
Page 1 of 1 (4 items) | RSS
