Hi, I am in the process of restoring a Beomaster 5000 (stacking system 80s version), the unit works aside from the front "open" and "power/pause/mute" button. When I got the unit the front panel was actually detached so it has lost its two pins/moulded plastic pieces that push the tactile switch on the PCB which is obviously the problem. Anyone have two of these moulded pieces I could buy? Or can think of an alternative solution to this problem?
I had considered drilling a small hole in the plastic which mounts to the aluminium trim and placing a flat headed screw which slots inside this hole at the right length and gluing this to the aluminium trim which might work as a last resort but guessed people on here might have either the right parts or a better idea!
Chris
Here:
