Hello B&O experts,
Is it possible to add a Beolab2 to my BeoVision 7-32 MKIII and Beosound 7.1? I have tried to configure it but the Beolab2 is always greyed out on the menu when the Beosound 7.1 is selected as centre speaker. I cannot figure out the correct way to connect them all together, hence my request for a solution to the experts on here..
Thanks in advance,
David
Guitardaddy:Hello B&O experts, Is it possible to add a Beolab2 to my BeoVision 7-32 MKIII and Beosound 7.1? I have tried to configure it but the Beolab2 is always greyed out on the menu when the Beosound 7.1 is selected as centre speaker. I cannot figure out the correct way to connect them all together, hence my request for a solution to the experts on here..Thanks in advance,David
Isn't it possible to just to keep current configuration.
BL7.1 as centre speaker.
Connect PL cable from Center PL output of the TV to the BL2 input PL socket.
Connect another PL cable from BL2 output socket to the BL7.1.
R.
Thanks for your response.....much appreciated! I will give your suggestion a try.
Thanks again,
Thanks for your reply.....it's much appreciated! I will certainly give your suggestion a try.
Update to connection question.
I finally solved the problem thank goodness. I tried all suggestions and even contacted B&O technical department and the very helpful Steve at Heavenly Sounds who all suggested similar connections. However, with all the recommended connections in place the BeoSound 7.1 suffered from compression artifacts which was disconcerting.,
In the end I left the Beosound 7.1 in it's usual Powerlink socket ( one of two on the back of the BeoVision 7-32 ) and didn't specify front, rear or subwoofer in the menu... just the centre speaker.
I plugged in the BeoLab 2 in the remaining Powerlink socket. Everything now works as it should... crystal clear with added deep bass.
Thank you all for your input.
