Volume Control on my 8000's
FieryJack
Posts 3
FieryJack Posted: Sat, Sep 19 2020 8:00 AM
Hi everyone , just joined , thanks for having me.I'm an absolute novice
to all this so please be patient.My question is this , I cannot adjust the volume on my 8000's. I recently purchased them off ebay and bought a brand new rega planer 3 , the shop I bought the turntable from asked me me what amp I was using....anyway , long story short   he got in touch with a b+o dealer who recommended using a quad preamp , which I bought off him brand new.
So , I've wired it all up , but no volume control....the indicator on the preamp shows an increase but constant volume , same if I push the mute  on the remote for the preamp.....no effect.
Jaffrey2230
Washington DC
Posts 520
You need an amp or source with a volume control.
B&O in my life 😊:
  • Beolab 8002 + Beolab 2 + Beosound Core with Essence Remote (Office)
  • Beolab 6000 + Beolab 11 + Beosound Core with Essence Remote (Bedroom)
  • Beoplay A9 Mk2 (Living Room)
  • Beosound 1 with wireless dock (Portable)
  • Beosound Balance (Dining)
  • Beoplay H95 (Focused listening, travel)
  • Beoplay H9 (3rd gen) (retired)
  • Beoplay P6 (Portable)
  • Beotime wall clock (hallway entrance)
  • BMW X5 50i with B&O Audio Package (Commute/drive)
lawrencejmcook
Posts 742
FieryJack:
Hi FieryJack,
If your Quad pre-amp has two sets of outputs, it could be that one set is volume controlled, and one at fixed level. Does the pre-amp User guide tell you?
You may have connected the BL8000s to the fixed-level outputs - but then they would be playing very loud!
Lawrence
FieryJack
Posts 3
FieryJack replied on Sun, Sep 20 2020 6:57 AM
I had connected them to the wrong outputs.
Works fine now.
Cheers.
Page 1 of 1 (4 items) | RSS
