I have a Beoplay H5 and I have been using since February 2018. Just today, the rubber button broke and it shows the parts inside. I am afraid that it may be exposed more easily to water and either it will get damaged or I will get electrocuted.Can anyone help me solve this problem?Thank you for your attention and help
Best Regards, Mit freundlichen Grüßen, 감사합니다Antonius Robin Iriawan, 로빈 올림
Beosound 35, Beoplay E8 3rd Gen, and Beoplay Earset 3i.
No longer in use: Beoplay H5
Same problem here. How did you figure it out?
MarcosAlvarenga: Same problem here. How did you figure it out?
The cable is torn badly. I think it happens because I pressed the button far too many(?)Now, I doubt that it will not happen to the E4 nor Earset as they have rubber buttons as well.
