Dear all,
I am looking for a wall mounting solution for my BV8-32. Right now I am using the close wall bracket from stbbrackets. Now I want to move the set to another room and there I would need to viewing positions with different angle and especially different height.
The height difference should be around 1m. Lower position at ~100-120 and higher position at around 1,80 - measured at top end of TV.
It would further be perfect if the TV can be tilt, but this is second to the height changes.
Does anyone of you have any idea how to fix this?
Thanks,
Heribert
BV 11-46 / Beoplay V1 -40 / Apple TV 1+3 / Beosound Essence MK2 / BL3 / 2* BL11 / BL 6000 / BL 12-1 / BL 2000 / 3 * Beo4 /BL Converter 1611
You could try something like this:
http://www.auton.com/products/lifts/plasma-lifts/
But you would need to check whether the mechanism obstructed the lower position preventing you from having an open front.
Two televisions might be cheaper, one set above the other, with a moving vertical screen to cover one at a time:
http://www.auton.com/products/lifts/panel-lifts/
Graham
Hello,
Thanks you for the tip, but this seems to be a sort of overkill for my needs and budget for this room. Perhaps anyone has another - easier and cheaper - idea?
How frequently will you need to move the TV between top and bottom positions?
You could convert your existing wall mount to run up and down on a floor to ceiling panel or column, maybe using the sort of counter balance used in sash windows.
