Hi all,
Hope you can help me with answer to this one:
I have a BV Avant 55, BLC and BeoSound 2 as music system. All speakers (BL 9 and BL3) are conected to the Avant. I would like to change BeoSound 2 to a BeoSound Core a music system, still with all speakers connected to the Avant. Will this work? And will the Avant power on when I select a source on the Core to play, in the same way as it does now when i play a scouce one the BeoSound 2?
Many thanks in advance for helping.
Regards,Ken
Hi. Tunein, deezer, line in and Bluetooth will work together with avant.
but when you Connect core as an integrated setup you will loose some function like AirPlay, chromecast and Spotify Connect. No way yo go around it.
Beosound core with integrated setup with the avant, this source will work:,
Tunein, deezer, line in and bluetooth
Apple AirPlay, chrome cast, Spotify Connect will not work. And its no way around. :)
Change your avant out with eclipse and harmoni, you dont need the core :) and alle the source work.
