Hello,
I've been searching the forum for this question but couldn't find it.
Is it possible to connect an AV9000 television to a MP 9000 with a converter T1611 instead of the AV 9000 connector kit, the T-1610?
All help is welcome!
Wouter
Just connect AV9000 and MPAV with a Masterlink cable. The have both ML sockets.
You need a 1610 for connecting a BS7000, 6500, 4500, BC9500...
Welcome to Beoworld.
Stefan
a full wired ML cable so to say!
Brengen & Ophalen
Thank you!
I would ad that the IMP versions of the Beovision AV9000 does use 1611 instead of 1610.
I had my Beosystem 6500 connected this way to my AV9000 and it worked great that way.
