Pair the Beoremote One and IR eye (Join version) to control Beolab 50 speakers volume
This post has 7 Replies | 3 Followers
jeffartik
Posts 2
jeffartik Posted: Thu, Oct 1 2020 1:50 AM
I'm trying since hours to control the volume of my Beolab 50 using the Beoremote One. What I read is that I needed an IR-eye, so I bought the "last" version (With join button) on Ebay. Here is the model:
Once received it, I connected it to the MIC/IR port in the master speaker, and set my Beoremote One in Beosound mode. But with this configuration, I was never able to control the volume of the speakers. I checked the wires order in the Eye, all are good, tried to change the connection port in the speaker, didn't work.
- Does this "Join" version works with Beolad 50?
- Does the Eye IR I bought from Ebay is simply not working?
- The IR eye is the right device I bought, or I have another solution to control BL50's volume with the beoremote one?
Any help is welcome.
Razlaw
Posts 4,345
Razlaw replied on Thu, Oct 1 2020 2:04 AM
I think you have the wrong eye. I have a join eye like you show connected to my Essence. The eye connected to my 50s does not have any markings on it.
Razlaw
Posts 4,345
Razlaw replied on Thu, Oct 1 2020 2:06 AM
There is some info in this thread.
https://archivedforum2.beoworld.org/forums/t/35599.aspx
leosgonewild
Helsinki, Finland
Posts 2,373
The BL50 doesn’t work out if the box with the Bluetooth version of the remote?
crossbytje
Posts 224
leosgonewild:
Exactly my thought!
Beolit 12 - Beolab 4 pc (dead now) - Beoplay H5 - Beolab 9 - BeoRemote One BT - Beoplay M3
jeffartik
Posts 2
jeffartik replied on Thu, Oct 1 2020 11:36 AM
What! That would be the news of the month for me haha. But I never saw any option to pair Beoremote One directly with BL50. As mentionned in this topix: https://archivedforum2.beoworld.org/forums/t/35599.aspx
"Note that, in order to control the BeoLab 50’s with the BeoRemote 1, two things must initially be configured. Firstly, the infra-red receiver (also known as an “IR Eye”) must be correctly connected to the Master BeoLab 50."
leosgonewild
Helsinki, Finland
Posts 2,373
Seems it is not possible.
Mr 10Percent
So West, Its Now East
Posts 591
I just checked the invoice for my IR Eye for my BL90s. There is no part type specified apart from "IR EYE for Beolab 90" and "Misc"
There is no join markings and there is no depression flex in the black strip (no clip button).
Essence needs to be in IR mode
BR1 needs to be in IR mode (Beosound mode)
Page 1 of 1 (8 items) | RSS
