Good day,
I bought a pair of Penta 6635's. For one I replaced the foam surrounds of the midranges, works great again.
However when I was going to start on the other one I noticed it does not come out of stand-by anymore. The led stays red. there is no blinking, no amber light or anything, just stand-by. I connect the speaker via the standard 8 pin beolink cable to a Beosound 3200.
Does anyone have any idea how to fix this?
Thanks in advance!!
Thanks for the suggestion.
If you mean the switches either underneath the amp, it is set to Audio, the selectors on the front of the Amp are set correctly as well.
