BeoSound Core to AppleTV
This post has 6 Replies | 2 Followers
Brendan
Melbourne, AUSTRALIA
Posts 6
Brendan Posted: Thu, Oct 15 2020 11:29 PM
Hi guys,
Just double checking that with Core I can stream to multiple AppleTV devices (not necessarily simultaneously)
I have a B&O Surround speaker setup on the V1 in my bedroom with an Apple TV
I have a B&O Surround speaker setup on the BV7 32 MK5 in my lounge with Apple TV
I just want to know that with Core I can select which rooms AppleTV to push the audio to...
My B&O Apartment:
(cabled but unseen ;-) WISA as indicated):
Lounge:
  • BV7 32" MK5 TV
  • BeoLab 7-1 (Centre)
  • BeoLab 3 on Stands (Fronts)
  • BeoLab 6002 (Surround - WISA)
  • BeoLab 19 (Sub - WISA)
Bedroom:
  • BP V1 32" TV (on ceiling cables)
  • BP V1 (centre)
  • BeoVox 2-1 In Wall "Passive" Speakers (Fronts)
  • BeoLab 3's (Surround Height STB BL-3-CM Ceiling Brackets)
  • BeoLab 6000 (Surround - WISA)
  • BeoLab 11 (Sub)
  • BeoAmp Passive
Coming Soon:
  • BeoPlay H95 HP's (outdoors)
  • BeoLab 15 Motorised in Ceiling (lounge)
  • BeoSound 9000 (lounge)
  • BeoSound Core (lounge)
  • Meze Emperyan Open Back HP's (indoors)
ebnrob
UK
Posts 174
ebnrob replied on Thu, Oct 15 2020 11:47 PM
Hi there, You can't airplay from a beosound core to another airplay receiver such as an apple TV, but you can distribute the core's internal sources (line in, Tune In, Deezer, Airplay) to your V1 tv using the beolink 'Join' command on your V1 (no apple TV needed for that). I hope that helps. Rob.
Brendan
Posts 6
Brendan replied on Thu, Oct 15 2020 11:53 PM
Thanks ebnrob, thats still handy!  So wirelessly correct?
I've been looking at my wiring options to essentially have;;
the lounge room connected BS9000 CD Player/Radio and the Core and the ability to port those to the bedroom.
I don't necessarily need to have two sources playing at the same time in different rooms (as it's a small apartment)...  So I figure if I forego CD, just being able to send CORE source into the bedroom would be good enough.  Will sure save me from a few holes in the walls and ceilings to wire up!  Currently there are 15 in the bedroom from putting in the ceiling and wall speakers!
Cheers.  Anyone else have any thoughts?
My B&O Apartment:
Lounge:
  • BV7 32" MK5 TV
Bedroom:
  • BP V1 (centre)
  • BeoLab 11 (Sub)
  • BeoAmp Passive
Coming Soon:
Brendan
Posts 6
Brendan replied on Fri, Oct 16 2020 3:19 AM
Can those internal sources be accessed via the App?   So I'm wanting to direct CORE "internal source" streaming (which it seems would only be Deezer) to the bedroom.
I didn't realise the V1's had any capability of connecting to other devices wirelessly....  Thats why I thought Apple TV would be the go since it's receiving WiFi.
The TV itself cant directly receive WiFi right?  So does this BeoLink "join" option require an Ethernet cable into the TV?
I dont have any ethernet connection near the V1, so I might have to add a wireless receiver or maybe an airport with a cable into the V1 TV?
Thoughts?
My B&O Apartment:
Lounge:
  • BV7 32" MK5 TV
Bedroom:
  • BP V1 (centre)
  • BeoLab 11 (Sub)
  • BeoAmp Passive
Coming Soon:
lawrencejmcook
Posts 742
The BeoPlay V1s - at least for the U.K. - came with WiFi transceivers and a wired external aerial. Have a look at the V1’s network connection settings. You may find that your WiFi is strong enough to be picked up without the external aerial.
If you find the signal is weak, you could either try adding a local WiFi point, or buying an aerial on an auction site (but they’re not common).
ebnrob
UK
Posts 174
ebnrob replied on Fri, Oct 16 2020 5:29 PM
Brendan:
You can configure the V1 to be linked to the Core (I think this is referred to as Product integration in the TV's settings) which will then list the cores sources on the V1 and you can map them to remote buttons on the v1 too, but for this to happen the V1 needs to be connected to the same network. You'll then see those remote sources in the b&o app too. Ethernet is best, but the V1 is wifi capable with an external aerial plugged into the back.
Brendan
Posts 6
Brendan replied on Sat, Oct 17 2020 4:42 AM
Thanks for the info guys, much appreciated!
My B&O Apartment:
Lounge:
  • BV7 32" MK5 TV
Bedroom:
  • BP V1 (centre)
  • BeoLab 11 (Sub)
  • BeoAmp Passive
Coming Soon:
Page 1 of 1 (7 items) | RSS
