Beolink 7000 rds version 1631 sw 3,0
This post has 16 Replies | 2 Followers
Andreasi995
Posts 20
Andreasi995 Posted: Sat, Jan 19 2013 5:59 PM
Hello.
I have a well function beosystem 7000.
Ihave set it up with my old beolink 7000 and the two way communication function normal.
I have bought another beolink 7000.
I tried to connect the "new beolink"7000 facing my beomaster 7000.
In the display ,no contact come up.I tried to remove my old beolink to another room and then tried again without luck.
I removed then all the audiosources-then store-then reinstalled thhe audiosources -then store but still no contact is remaining in the display.
The "new beolink 7000"does not function as a two way comunicator,just as a one way communicator.
Is there anybody out there which can help me solving this trouble.
kallasr
Germany
Posts 2,562
kallasr replied on Sat, Jan 19 2013 7:07 PM
Search the (archived) Forum... Issue has been covered several times.
Best regards
Ralf
Andreasi995
Posts 20
Thanks Ralf.
I will looking for the answer
But if you can explain the solution of my problem i will welcome it.
The Viking
kallasr
Germany
Posts 2,562
kallasr replied on Sat, Jan 19 2013 8:03 PM
I don't know but it is on this website...
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Sat, Jan 19 2013 8:10 PM
Probably 4 caps that needs to be replaced!
Check this!
Brengen & Ophalen
Andreasi995
Posts 20
Thanks Leslie
You are showing me 4 caps but  the picture shows 2 new installed caps.?
Where can i buy such caps?
And do i need to install them?
The Viking
Andreasi995
Posts 20
I mean what do i need to install them?
The Viking
Johan
Uppsala, Sweden
Posts 239
Silver Member
Johan replied on Sat, Jan 19 2013 9:37 PM
If you don't know, you should probably let someone else do it. Where do you live?
/  Johan
Andreasi995
Posts 20
I am living in the city of Trondheim/Norway.
Best regards
The Viking
Leslie
Posts 5,423
Silver Member
Leslie replied on Sat, Jan 19 2013 10:20 PM
You do need skills to do the job especially for the SMD caps under the tin can.
If you're not experienced enough let someone else do the job!
I put comments on each slide, 4 caps...
Brengen & Ophalen
Johan
Uppsala, Sweden
Posts 239
Silver Member
Johan replied on Sat, Jan 19 2013 10:26 PM
Andreasi995:
Ok, that's useful info, perhaps someone on the forum knows where you could go. As Leslie says, if you have no experience with this sort of stuff you should leave it to someone who does.
/  Johan
Andreasi995
Posts 20
Thank you very much Leslie.
You are very helpful.
I cant thank you enough.
I am no searching for a guy here in Norway to do the job.
I hope i can find someone.
I have myself replaced the old battery for a new one.
Do you know if there is other batterys inside the beolink which have to be replaced?
Andreasi995
Posts 20
Thanks Johan.
I sm no searching for someone in Norway to do the job.
Do you know someone in Sweden to work it out?
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Jan 25 2013 11:02 PM
Shall I have a look at it?
Brengen & Ophalen
Andreasi995
Posts 20
Thank you for your offer.
I will first try to contact some bang olufsen dealer here in Norway.May be they can repair the item.
I spoke to a bang olufsen seller in Oslo and he told me that i probably have to replace 4 or more caps(as you told me in beoforum)
He reommended too ,to replace a litium battery inside the beolink and at the same time set in a new blue display.
If they cant help me i hope i can come back to your offer?
Is i possible for you to replace caps,litium battery and the blue display???
Best regards
Per-Arne
Leslie
Posts 5,423
Silver Member
Leslie replied on Sat, Jan 26 2013 10:56 PM
Sorry, never replaced the backlight thing but as you might know there is an excellent thread how to do that. I have ordered the materials but still need to do this job!
Brengen & Ophalen
Andreasi995
Posts 20
Hello again.
I have no discovered that my beolink 7000 is not av version 1631 but 1540.
I bought the item on the ebay and the seller announced it as av version 1631 .
I saw the description underneath the beolink when elevated.
I paid euro 365.
1)What is the main
difference between version 1540 and 1631.?
Is that the reason of ,no contact in the display facing my beomaster 7000.?
I have no user manual for the version 1540.There are some differences on the red display button
.Control has replaced the clock button.
2)Will rds work out?
3)Are the caps which have to be replaced different?
So long
Per-Arne
Page 1 of 1 (17 items) | RSS
