Hi all,
I have a Beoplay A9 4th gen. without GA. That was very important for me, because I don't want these lights at the front and Google listening. Everything woked fine until I changed the Wifi today by GoogleHome (I hate the installation-procedure from the A9). Suddenly the four red Dots appeared at the front and I have no Idea how I can get rid of them.
Had somebody the same Experience? Idea to solve the Problem?
Chris
EDIT:Title typo corrected from font to front.DillenBeoworld moderator
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
Let the dealer replace it - it seems that you have bough one without GA, but has become one with.
Millemissen:Let the dealer replace it - it seems that you have bough one without GA, but has become one with. MM There is a tv - and there is a BV.
Okay, Problem solved. For everybody who is interested: The A9 without GA has still a microphone for "automatic sound settings". You can activate/deactivate it with the "Reset/Mic button". The user guide wasn't very helpful here...
Hi - just pressing that Mic/reset button once? I got same problem. Thanks a lot
