Everything working well but one day (maybe due to low batt) the BR1 restart (I saw BEO logo).
Fast everything is ok but I can not assign both right MYbuttons !!! left are ok.
Into Advanced menu I see MYbutton for the right side. After pressing arrow down I should see the left side buttons but I see again the right side button.
Bug ???
Again after battery failure (the battery low never cames on) I canot assign Source on the right MYButtons... The scrolling show only the 2 right myButtons...
Nobody has the same bug ?
Boot 201
App2 7 38
BLE0138
DB0318
I've had this same problem with several of my BeoRemote One remotes. However, I haven't noticed it being related to the battery. Sometimes it's the TV and MUSIC buttons that cannot be assigned. Restoring the remote to factory settings always fixes the problem. It's just a pain to have to rename the CONTROL and LIGHT buttons that I've renamed.
Thanks beojeff,
"Happy" to know that it's a BEO bug !
I also founded the full reset restore it but as you said it boring to rename all control/device and to reconfigure all the remote!!!
Not very professional for a remote control of this price...
Do you have any earlier version than mine ?
thanks
