Carolpa:it is a sync setting; I thought you have to unbox it.
Ahh. I haven't synced via Mac in quite a while; I'd forgotten that option. Thank you both!
Antonius Robin Iriawan:So far, no new update. I will keep you updated on the post that you mentioned.
I received an update: B&O ack the bug for both AIFF and WAV files. Should be fixed in one of the coming App releases.
mbolo01: I received an update: B&O ack the bug for both AIFF and WAV files. Should be fixed in one of the coming App releases.
Merci for your update. I have not received any reply yet from them. :-)
Best Regards, Mit freundlichen Grüßen, 감사합니다Antonius Robin Iriawan, 로빈 올림
Beosound 35, Beoplay E8 3rd Gen, and Beoplay Earset 3i.
No longer in use: Beoplay H5
