Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
Might be an update for the other products as well?
Please report your findings!
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
Same here. No updates to US.
B&O in my life 😊:
Dyssegaard:The resent sw updates to M5 and other NL- speakers seems to have added this funtionality to both the Halo and the BR1 BT .
ngnear:I‘m in Europe and no update(s) up until now.
Eclipse 65V1-32Beosound M5Essence MK2BLI
My Stage update to the 24 firmware yesterday. Nothing for the M3.
mbolo01:I guess this is related to remotes updates
I guess that is why the Moment isn't supported - there are no software updates planned for it. :(
I really want a stage for my bedroom and a Halo for the kitchen. But the Stage doesn't support Deezer which I listen to as I fall asleep every night, and the Halo doesn't support the Moment which I use all day long.
It's really a shame that B&O has given up on backward-compatibility. :( It was such a strength of theirs for so many years.
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2 Integrated: 1x Beosound 2 • 1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6 Control: 16x* Essence Remote • 1x Beoremote Halo
* Yes, really! 🤦♂️
laseralex: But the Stage doesn't support Deezer which I listen to as I fall asleep every night
The Stage does support Deezer, just like any other NL-speaker!
My M5 have problems since the latest FW update (october 27). When I started M5 in the morning to join what is played on the other devices in the house the sound is super "choppy" during a minute and the goes silent. Its not possible to add using the app. Restart is the only solution. This has happened the two latest mornings. The list of "critical event" is super long. Pasted example what it looks below, from when I started the device this morning until I did the restart. I have reported to B&O support.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hiort:My M5 have problems since the latest FW update (october 27). When I started M5 in the morning to join what is played on the other devices in the house the sound is super "choppy" during a minute and the goes silent. Its not possible to add using the app. Restart is the only solution. This has happened the two latest mornings. The list of "critical event" is super long. Pasted example what it looks below, from when I started the device this morning until I did the restart. I have reported to B&O support.
Hiort: My M5 have problems since the latest FW update (october 27). When I started M5 in the morning to join what is played on the other devices in the house the sound is super "choppy" during a minute and the goes silent.
I thought the choppiness was a feature exclusive to the Moment. I guess B&O are rolling it out to the other NL products.
Dyssegaard: My M5 is on a cabled ethernet connection, and I have not experienced any problems since the sw update.
Good for you
I have been instructed by B&O support to disable the "Bluetooth Always Open", and been asked a few questions around my case. Will see what happens. Maybe I should connect with cable...
andy_js:I thought the choppiness was a feature exclusive to the Moment. I guess B&O are rolling it out to the other NL products.
Hiort:The list of "critical event" is super long.
Updated my M5 and BS1
Works perfect!
mbolo01: What kind of WiFi network do you have? Mesh? 2.4 / 5 GHz ?
No mesh. Two Unifi access points. M5 is on 5 GHz. M5 show excellent signal strength.
I´ve got tired and wired my M5 to Internet.
Checked the critical events list this morning, and this is what it looked like. Can this be normal?
Hiort:Can this be normal?
Surely not, I would consider a factory reset unless your wired connection is OK and you don't want to take the risk of such reset.
I have the same problem. Seems like there is network connection problems.
I have tried several factory resets. The issue keeps coming back. Next thing i will try is to reset my wifi at home to see if that causes the problems.
Before the latest update I didn't experience any problems or critical errors in the logs.
Any information or news regarding this problems?
https
Double post
Dyssegaard:New sw available for M5: 1.24.40905 I have installed it and it works just fine. I cannot see any changes so far to functionality or setup menues.
I have also installed version 1.24.40905.
It appears to work fine, in general, and I have not experienced any network issues as mentioned by others.
I have noticed, however, that connecting to TuneIn stations fails sporadically. Maybe once every 5-10 times. I am not sure if this is related to version 1.24.40905, issues at tunein.com or issues at the streaming servers. It seems to fail randomly and not just for a single station. It works when the station is selected again. The device does receive the command as it stops playing and signals that it is connecting to another station. Reproduced via the B&O iOS app. The wifi connection is stable and the "critical event log" has only "TuneIn:" entries.
JGrusgaard:I have the same problem. Seems like there is network connection problems. I have tried several factory resets. The issue keeps coming back. Next thing i will try is to reset my wifi at home to see if that causes the problems. Before the latest update I didn't experience any problems or critical errors in the logs. Any information or news regarding this problems? https
Hiort:According to support the issue are with Hq.
1990: laseralex: But the Stage doesn't support Deezer which I listen to as I fall asleep every night The Stage does support Deezer, just like any other NL-speaker!
The Stage has built-in Deezer? Not just "Join" over NL or chromecast/airplay streaming?
The product page at https://www.bang-olufsen.com/en/speakers/beosound-stage lists only TuneIn under the connectivity section:
Integrated music services TuneIn internet radio
If it has Deezer, I'm buying one!
Hiort:I mean that the development team now are looking at the logs. Livingroom: BL3, BL11, BV11-46 Kitchen : Beosound 1 GVA, Beocom 2 Bathroom : M3 Library : A6, Beocom 6000 Bedroom : M5 Office : Beocom 2 Travel : Beoplay E8 2.0, Beoplay P2
Dyssegaard:Version 1.24.41628 for M5 is available now (in Copenhagen). I have installed it, and as far as I can tell, there is no new funtionality. Hopefully it is a bugfix that will take care of your problems with the previous update. Best regards - Dyssegaard Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K, Bedroom: Beovision 11-40 , AppleTV 4 . Home office: Beolit 12, Kitchen: Beoplay M5 . Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
Have notification of a new firmware (1.24.41628) in the app now.
Will update and keep fingers crossed...
Hi Razlaw,
I am currently listening to that TuneIn station (s95144) on an M5 with v1.24.40905.
$ export BEOPLAY_NAME="Beoplay M5 i køkkenet" $ beoplay-cli tuneIn s95144 $ beoplay-cli monitor RemoteCore.NotificationBridge.DataConnectionNotification(state: RemoteCore.NotificationSession.ConnectionState.connecting, message: nil) RemoteCore.NotificationBridge.DataConnectionNotification(state: RemoteCore.NotificationSession.ConnectionState.online, message: nil) RemoteCore.Source(id: "", type: "", category: "", friendlyName: "", productJid: "", productFriendlyName: "", state: RemoteCore.DeviceState.unknown) RemoteCore.Progress(playQueueItemId: "", state: RemoteCore.DeviceState.unknown) RemoteCore.Volume(volume: 15, muted: false, minimum: 0, maximum: 90) RemoteCore.Source(id: "radio:2714.1200304.28096178@products.bang-olufsen.com", type: "TUNEIN", category: "RADIO", friendlyName: "TuneIn", productJid: "2714.1200304.28096178@products.bang-olufsen.com", productFriendlyName: "Beoplay M5 i køkkenet", state: RemoteCore.DeviceState.play) RemoteCore.Progress(playQueueItemId: "plid-5794", state: RemoteCore.DeviceState.preparing) RemoteCore.NowPlayingRadio(stationId: "s95144", liveDescription: "", name: "s95144") RemoteCore.Progress(playQueueItemId: "plid-5794", state: RemoteCore.DeviceState.preparing) RemoteCore.NowPlayingRadio(stationId: "s95144", liveDescription: "Luigi Boccherini (1743-1805) - Quintetto per archi in do Maggiore G310 (Richard Lester, primo violoncello - The Vanbrugh Quartet)", name: "Venice Classic Radio * Auditorium") RemoteCore.Progress(playQueueItemId: "plid-5794", state: RemoteCore.DeviceState.play) RemoteCore.Progress(playQueueItemId: "plid-5794", state: RemoteCore.DeviceState.play)
After B&O support confirmed receipt of logs from me and kept silent for 12 days I received the following:
"Thank you for reply.We're sorry to hear you're still having issues with your Beoplay M5, we've confirmed that this issue is related to the software and not the hardware of the Beoplay M5, we don't have an estimated time frame as to when we'll have this resolved as yet, we can assure you resolving this software issue is a priority for us, and we'll update you as soon as possible, we recommend you power cycle when this occurs as we don't have another work-around for it.We appreciate your patience & understanding, please, do not hesitate to contact us again if you have a doubt or another question."
I have continuously fed them logs during this time and explained what is happening.
Now I just keep my fingers crossed that they fix this. Thereafter I will shut of the automatic FW updates....
Sad news .... I would ask and insist to have the working version of the firmware made available for you to download and install the time they fix the issue. I have done that for my Core that is not working properly since March update.
