I've recently started using my Beomaster 3300 again after a few years.
It's worked perfectly for about 3/4 months whilst I've been using it for my record player and PC sound. However, the other day I went to listen to some music and for some reason completely unknown to me whenever the music hits a crescendo or there is a large amount of bass in the song, the beomaster automatically turns itself down.
I've browsed various forums and spoken to a few people about the issue and I've yet to find an answer or even someone suffering from the same issues.
I'm not particularly skilled with the interior components of the beomaster but any help would be greatly appreciated.
Kind regards,
Riley.
I can also provide videos if need be.
Weak power supply, I would guess.I would check the rectifier diodes first - replace filter capacitors next.
