Beocenter2 + Beolab 3500 + non B&O sub (active)
This post has 0 Replies | 0 Followers
HHvitman
Posts 17
HHvitman Posted: Wed, Oct 28 2020 4:17 PM
I´m looking into bying a used Beocenter 2 (Master and Socket unit)
I want to use my existing Beolab 3500 as a main speaker and a non B&O sub (Dali, active) in the same room/system.
Can the BC2 send out sound signal through powerlink and masterlink at the same and possible, volume level set by BC2/Beo4
Is it possible than to Connect like this?
- Beolab 3500 connected with ML cable to BC2 (BL3500 in Option 0 i guess, disable IR or?)
- Connect the sub to the power link connection for the BC2 (din (Bc2) to rca(sub))
- Input sound connected to Aux In (rca)
- Power on BC2 and BL3500 (activated through ML?) with my Beo4
-Main volume to be set by Beo4/BC2
I do have a Beolink 1611 converter also
Should I instead use powerlink split, 1 to 2?from BC2 to:
1x into sub
1x BL3500 via Beolink 1611
Any ideas? :)
Page 1 of 1 (1 items) | RSS
