Hi All,
I recently purchased a much loved Beocenter 7000. It has just had a full electrical service so is working and sounding amazing. It is however let down by the stainless steel program cover as the right hinge is broken. Does anyone know if these can be repaired? (maybe a strong glue or solder) or have one as a spare they are prepared to part with?
Thanks in advance
So an update.
I decided to try a repair on the hinge. I drilled both halves and inserted a small pin to add strength then bonded together with araldite and left to harden for a couple of days. Then finally used a small engraving bit to smooth down any excess. I haven't reassembled it yet, so fingers crossed it will be strong enough.
