Before I had Masterlink Gateway and used Light commando to switch on lights etc every evening..It worked flawlessly..
I then installed Beolink Gateway (disconnected my Masterlink) and installed all scenarios again. It worked for a while, then light-commando stopped working..
I restarted the beolink and it started to work again but only for a while..
I have 10 zones, mostly with older Masterlink-products, but also a netlink converter and a Beovision 11-46 in my bedroom.
Everything is wired with RJ45 cat7..
Hi jg1976,
What firmware do you have on the BLGW, and what ML products?
