BeoGram/Cord 3500 glass film scratch removeable?
Liljewall
Posts 5
Liljewall Posted: Sun, Nov 1 2020 6:48 PM
Hello there! I just baught a BeoMaster 3500 sytem with BeoGram and BeoCord.
But there are some Scratches/dents on the glassfilm on the Cd and cassette units touch glass.
As seen in the included picture below. There is no broken glas. Is there a film under the glas panel that have gotten these scratches in some way and can one replace this film?
Any help with this questions would be greatly appreciated!
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Nov 2 2020 6:48 AM
The glass has been glued to the plastic frame parts using something bad.
If only black areas are affected, you can take it apart and paint the areas from the backside using black Humbrol paint and a small paint brush.
A surprisingly good result can be made this way.
If other areas are affected, the easiest solution will be a replacement glass panel.
Liljewall
Posts 5
Thank you for the information!. I will try and fill in the black areas with this. But there are also areas where the red numbers show, that have some scratches..  Do you have any good links for stores that sell these panels?  I have been looking for sites that sell spareparts but dont find anything that could realy help me.
Thanks again for the info you provided me with!
/ Liljewall
Page 1 of 1 (3 items) | RSS
