Hello,Has anyone here done an install with a BeoSound SoundCenter and a TV separately from each other? Like a wall mounted SoundCenter + a wall mounted TV a bit above? I am curious about if it can be made in a nice way so that the mounting for a TV is concealed. Reason for this is to be able to use a bigger monitor with a smaller SoundCenter as the wall won't allow for a wider than the 55" model Sound Center.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
I have done precisely this with a Eclipse 55 SoundCenter with a LG C9 65 on top. Main challenge is to attach the soundcenter to the wall without the original 600EUR wall bracket.
flatwhite:I have done precisely this with a Eclipse 55 SoundCenter with a LG C9 65 on top. Main challenge is to attach the soundcenter to the wall without the original 600EUR wall bracket.
See my original post. Will upload new pictures shortly.
https://archivedforum2.beoworld.org/forums/p/42604/310808.aspx#310808
If you separate the two you will either see your ugly bracket in the middle, or the long metal panel on the left side with the original bracket.
https://www.avensyshome.co.uk/p-90011-bang-olufsen-beovision-eclipse-motorised-wall-bracket.aspx
Would love to see that.
Another, expensive option would be the STB close wall bracket https://www.stbbrackets.co.uk/en-GB/product/BeoVision-Eclipse/BeoVision-Eclipse-Close-Wall-Bracket
So from a software standpoint, you just download the B&O app, connect the SC and TV via ethernet cable and all surround sounds and beoremote one work to control the TV and SC?
Yes.
