Hi martin
would you have detailed sizes of ms 150 stands, i don't think i'm going to find any, look at getting some made.
marc
yes your right i just seen it in the manual, good job i did not throw it away it was tucked under box flap and i thought it could have been something fallen into the box over the years.
I have this drawing for speaker stand, insert your own measures, mentioned earlier in this thread, as for material I suggest 3/4 x 3/4 square steel tube or even 1" x 1", Maybe Dennis could come with further dimensions. I made a "nose" on mine (second pic) without nose you cant adjust to "0" degrees vertical. Also check the hole distance on the speaker, screws are on mine M5.
mdm123: yes your right i just seen it in the manual, good job i did not throw it away it was tucked under box flap and i thought it could have been something fallen into the box over the years. marc
Marc,
I have a spare pair of MS150 stands. They're a bit tatty and have been re-painted silver by hand using a brush, so they could do with smartening up but they're solid enough. They're yours for the cost of postage if you want them - send me a Private Message with your email address if you're interested!
Adam.
thanks so much, nice stands by the way.
Hi Adem
I will be very interested in your stands
Hi Adam,
Are the MS 150 stands still available?
Thank you so much
As the original thread is from 6 years ago, I’m afraid they went a long time ago!
AdamS: As the original thread is from 6 years ago, I’m afraid they went a long time ago!
Trouble is, there is so little information about B&O anywhere else that people desperately try to find something here... so badly that they don't look at thread dates !
Hey, by the way, how about some Beomaster 8000 vintage review in HFN&RR? Can you ask Tim?
Jacques
It is definitely long overdue. I'll give him a nudge!
AdamS: It is definitely long overdue. I'll give him a nudge!
That would be great Adam, thanks.
