Hi, I use BLI wtih Alexa, but in the Alexa app, I cannot select my B&0 Spealkers as default for the Group (e.g. kitchen). The speak do show as speaker under devises, but we I select the "SPEAKERS" for the group (green circle) i only see my Denon HEos Speaker and non of my B& Speakers.
any hits??
I <
Hi JensHauge,
Indeed Amazon has developed speaker groups like the ones available in the BeoLiving app. The issue is that the speakers are not yet compatible with the ones Alexa has developed this feature for. You should configure the product groups from the BeoLiving app!
Best,
Ivan from the Khimo team.
Thanks Ivan, can you share a screendump what you mean? I've already created the those I believe....
so I cannot select them as Speakers under the Alexa App like the RED cirkle below, until Alexa certify B&O Speakers. As for now they show as decive as per the YELLOW cirkel.
/jens
