Bang & Olufsen App 3.8
This post has 49 Replies | 4 Followers
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, Jan 21 2021 11:38 AM
Version 3.10 out in Testflight.
The rather confusing WiFi symbols are back.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Thu, Jan 21 2021 1:47 PM
Hiort:
.... but aligned!
There is also a new Diagnostic section, promising, but confusing as incorrect status are reportes .... they warn it is a beta!
WIDGETS are gone
Numerous old and reported bugs/inconvenience are still there, as usual.
Dyssegaard
Copenhagen, Denmark
Posts 263
mbolo01:
.... but aligned!
WIDGETS are gone
Same thing for my setup - except that Widgets are still present and ok.
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Thu, Jan 21 2021 5:09 PM
Dyssegaard:
Thanks for sharing. I restarted my iPhone (XR latest OS) and Widgets are now back
beojeff
USA
Posts 2,012
beojeff replied on Sat, Jan 23 2021 10:41 AM
What I would really like to see is the option to adjust the level of specific sources to obtain the same volume level across sources. It surprises me that others aren't really annoyed at having to reach for the remote to lower the volume for TuneIn and Radio sources and to have to raise the volume of turntable sources. It would seem like a simple feature to add.
Vintage_B&O
Germany
Posts 303
I would like TIDAL Support in the App and native support.
garethr
Posts 10
garethr replied on Mon, Jan 25 2021 6:50 PM
Is there any reason why changing the dot size in Beosonic is now back for headphones - I’d thought it was removed due to a channel imbalance issue?
More critically thought since 3.9 (on iOS) the default ‘optimal’ setting now has the dot slightly enlarged which is a complete change in sound signature from earlier versions. Was this intentional or a QA problem?
This is with the H95, but I don’t know about it he rest of the headphone line.
tiktak
Posts 13
tiktak replied on Thu, Jan 28 2021 8:27 PM
Would like a "search" option in DLNA for the app.
Just like "VLC for Android". B&O already developed a DLNA search option for Beosound Moment. It feels hopeless to have to being forced to scroll down your entire music library manually everytime.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Fri, Jan 29 2021 1:09 PM
I may sound like a broken record but It’s really a shame that B&O coders are not able to simply retrieve the album cover from a B&O product when AirPlay is the source (and the cover image is available). With a media_player card in Home Assistant it is definitively possible so why not with B&O app itself ???
BS Core playing an AirPlay source in HA:
Same from the B&O App Confused
matteventu
Posts 91
garethr:
Changing the dot size has always been there for some headphones (i.e. H9 3rd Gen).
Now btw in version 3.10 (which is currently in beta, I'd expect it to go to stable in a week or two) they've fixed the bug which defaulted the Optimal (or Signature, in some other devices) sound preset to having a slightly enlarged dot (bug introduced about two weeks ago).
With the H9 3rd Gen, though, the custom preset is still not always saved to the headphones (sometimes it automatically reverts to Optimal, even if you set it to another one).
Page 2 of 2 (50 items) < Previous 1 2 | RSS
