Hello,
Wondering about how the sound quality, loudness and general audio fidelity is compared between these two systems. I have a pair of Beolab 8000 connected to a V1 40 in my bedroom and I am considering shifting over to an LG oled + stage and need to know if it will be good enough on its own. Or if I should just keep the current setup.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Two rather different solutions - each to its own with their pros and cons.
If you are happy with the current setup, why worry?
Who knows what will come later from B&O!
Millemissen:Two rather different solutions - each to its own with their pros and cons. If you are happy with the current setup, why worry? Who knows what will come later from B&O! MM There is a tv - and there is a BV.
I love my stage. It has a very good sound, strong bass and I appreciate the diversity of the sources.
BeoVision 7-40 HD-Modul, BeoViision 11-40, BeoVision 8 32" white + Floor Stand, 2x Apple TV 4 mit Kodi, DVD2, HDR2, BeoSound 9000 MKIII White Edition, 2x BeoSound Moment + Floor Stand, 2x BeoSound Stage, BeoSound Core, BeoSound 35 brass, BeoSound 1 MKII + Floor Stand, 2x BeoSound 3, BeoSound 6, BeoSound 3200, BeoSound Essence , BeoPlay A9 Nordic Sky twilight, BeoPlay A8 MKII white + Floor Stand, BeoPlay A2 grey, 2x BeoPlay A3 white/bright blue, BeoPlay A1, 2x BeoPlay S3 white, Beolit 12 (White Edition), Beogram TX2, BeoLab 5, BeoLab 3, BeoLab 7-4, BeoLab 8000 MKII, Beolab 11, 2x BeoLab 3500, 4x LC2, 4x Beo4 - MK1-3, BeoRemonte One BT, 2x BeoRemonte Halo, Audio Terminal, Beolink 1000, BeoLink 7000, 2x EarSet A8, 3x A9 Keyring, EarSet 2, Form2, BeoPlay H6, 3x BeoTime, Beowatch, 2x Lightmanager Pro+ B&o Version, 4x BeoCom5, Beoline2, 3x Speakerphone, BeoTalk 1200, 5x Cabinets, MLGW, BLGW,
Iceman10245:I love my stage. It has a very good sound, strong bass and I appreciate the diversity of the sources. BeoVision 7-40 HD-Modul, BeoViision 11-40, BeoVision 8 32" white + Floor Stand, 2x Apple TV 4 mit Kodi, DVD2, HDR2, BeoSound 9000 MKIII White Edition, 2x BeoSound Moment + Floor Stand, 2x BeoSound Stage, Beosound Core, BeoSound 1 MKII + Floor Stand, 2x BeoSound 3, BeoSound 6, BeoSound 3200, BeoSound Essence , BeoPlay A9 Nordic Sky twilight, BeoPlay A8 MKII white + Floor Stand, BeoPlay A2 grey, 2x BeoPlay A3 white/bright blue, BeoPlay A1, 2x BeoPlay S3 white, Beolit 12 (White Edition), Beogram TX2, BeoLab 5, BeoLab 3, BeoLab 7-4, BeoLab 8000 MKII, Beolab 11, 2x BeoLab 3500, 4x LC2, 4x Beo4 - MK1-3, BeoRemonte One BT, BeoRemonte Halo, Audio Terminal, Beolink 1000, BeoLink 7000, 2x Beo6, 2x EarSet A8, 3x A9 Keyring, EarSet 2, Form2, BeoPlay H6, 3x BeoTime, Beowatch, 2x Lightmanager Pro+ B&o Version, 4x BeoCom5, Beoline2, 3x Speakerphone, BeoTalk 1200, 5x Cabinets , MLGW, BLGW,
I have the Stage + LG setup and know the Beolab 8000 from my uncle's place.
The Stage sounds great and much better than you'd expect from the size and price. The soundstage is very wide and the bass is pretty punchy, though there is a lack in very deep low bass. It's a bit hard to compare them to the Beolab 8000 because I only listened to music on them a couple of times while I do TV and music 50/50 with the stage. I'd say the BL8000 give you the real stereo feeling, sound a bit more airy and has a more defined midrange response, noticeable when listening to acoustic / songwriter music. The stage seems to be the more complete package and better fit for an all-round TV setting though. If talking pure quality, some may prefer the sound of the BL8000 but it's hard for me to compare them without keeping in mind the many flexible use cases you have for the stage.
I'd say: If you don't need the surround audio processing in your bedroom for future upgrades then the Stage will be an excellent fit. It also looks great with the LG OLED and is a very space-savy
I have both and as others have said the sound is different. The stage is great and I personally think it sounds fantastic with more than enough bass, however you are physically limited by the width/height of the bar (like all soundbars) so you don’t get that true big wide & high soundstage you get with the 8000s or any separates to be honest.
The stage is a perfect all rounder and does the movies, tv and music to a very high standard and would rather match the stage with a tv than the 8000s - they just can’t compete with the 8000s for music so I use them as music only. Don’t get rid of the Beolabs - just use them somewhere else!!
I have a Sony OLED and my option was to use a Stage or BL 8002 + BL 2. I also have a Core so my connection is using optical from TV to Core to BL 2 to BL 8002. In my experience, the BL 2/8002 combo has much deeper bass and can get very loud and immersive. The Stage has a much wider soundstage but the bass is not nearly as deep. Like others have said, it depends on your needs. I decided to go with the BL2/BL 8002. Without the BL 2 and Core to help the BL8002, the Stage wins - no contest.
B&O in my life 😊:
The Beolabs seem better and better. I think they shall stay a bit and then we will see in the future :). I do love them and they dont make anything bad anyway. Maybe I should refoam them though so they last longer..And as I already own them, there is no extra cost to think of. Should I replace the V1 then I can use them very simply with more or less everything but I can't get the BeoRemote One feature easily I guess without a Stage (if using a non-B&O tv)
