Beogram 4000 no power
This post has 35 Replies | 2 Followers
BeoWaff
Posts 25
BeoWaff Posted: Mon, Jan 21 2013 11:10 PM
I received a Beogram 4000 with a Beomaster 4000 for Christmas from a very lovely girlfriend! Only problem is I have just set it all up to find that the Amp works fine although the turntable just wont power up.
Does anyone know what could be wrong with it? it was apparently all working before I got it?
Any help would be appreciated.
Søren Mexico
Mexico City
Posts 6,411
The BG 4000 has a fuse (or 2 ??) inside, that is the first thing to check, if the fuse is blown, check the transformer primary and secondary lines before putting in a new fuse.
BeoWaff
Posts 25
BeoWaff replied on Tue, Jan 22 2013 12:02 AM
Thanks Soren,
I will check the Fuses tonight and see if any of them are blown.
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Tue, Jan 22 2013 8:36 AM
BeoWaff:
Great girlfriend !  :-)
BeoWaff
Posts 25
BeoWaff replied on Sun, Feb 10 2013 11:21 PM
Hi Soren,
I finally had a chance to look into the fuse problem with my beogram 4000, I found one of the fuses was blown.
I had a look at the transformer primary and even had a new plug rewired as the old one looked vintage.
The only problem is i need to know what the replacement fuse is? it has T250/250 on it, does that mean i need a 2.5A fuse to replace?
Thanks in advance.
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Sun, Feb 10 2013 11:39 PM
No, 250mA slow
Brengen & Ophalen
Søren Mexico
Mexico City
Posts 6,411
Leslie:
No, 250mA slow
Depending on where you BG was sold, you have a US or EU type of fuse, bring it with you the shop, to get the right one, and buy at least 2 pieces.
If the fuse blow again, you will have to check for failures, best to start up with a dim bulb tester, that will save fuses.
BeoWaff
Posts 25
BeoWaff replied on Mon, Feb 11 2013 12:46 AM
BeoWaff
Posts 25
BeoWaff replied on Mon, Feb 11 2013 12:47 AM
It was originally from the UK, I will buy a few of them as spares.
BeoWaff
Posts 25
BeoWaff replied on Mon, Feb 11 2013 2:59 AM
http://australia.rs-online.com/web/p/cartridge-fuses/7258026/
Is this the right one?
thanks
Søren Mexico
Mexico City
Posts 6,411
Yes Sir
BeoWaff
Posts 25
BeoWaff replied on Mon, Feb 11 2013 3:48 AM
Great, thanks for all your help.
I will order them now and let you know how i go when i receive them and put them in.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Feb 11 2013 6:50 AM
If you live in a 110-120V area and moved the Beogram from a 220-240V area, you will have to set the mains voltage
on the switch (unpowered) and change the fuse accordingly.
If 250mA was correct for use in 110-120V areas, you will need 500mA to stop the fuse(s) from blowing in 220-240V areas.
Remember Ohms law ? Yes - thumbs up
BeoWaff
Posts 25
BeoWaff replied on Tue, Feb 12 2013 3:52 AM
Hi Martin,
The person I purchased the set up from purchased it in England in 1972, he later moved to Australia and brought it over with him.
He said he has used it while he was here so i'm just replacing the fuse that is already in it. I guess if they blow then I will up to the 500.
BeoWaff
Posts 25
BeoWaff replied on Thu, Feb 14 2013 1:18 PM
Hi Guys,
I replaced the fuses but no luck, still no power!
Any idea of the next thing to check? anything you would replace? Transformer? how do i test it?
Thanks.
Dillen
Posts 13,191
Dillen replied on Thu, Feb 14 2013 1:38 PM
Did the fuse blow again ?
Did you replace the fuse with a correct value or "just a similar" ?
BeoWaff
Posts 25
BeoWaff replied on Thu, Feb 14 2013 11:04 PM
No the fuse didn't blow again.
The fuse cover says '2x0,25A.TRAG'
So the fuse I ordered was this one - Here
Is that the correct one?
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Feb 15 2013 6:30 AM
Just one question: did you unplug the deck with the carriage to the left?
If so, press STOP to switch it on! Otherwise it will not wake up!
Jacques
BeoWaff
Posts 25
BeoWaff replied on Fri, Feb 15 2013 12:45 PM
I just tried what you suggested and no luck.
There is power getting to the fuses as I stupidly touched them and got an electric shock, this is getting frustrating! I have had this record player since Christmas morning and haven't been able to get it to power up.
BeoWaff
Posts 25
BeoWaff replied on Tue, Feb 19 2013 12:35 AM
Does Anyone have any other ideas as to what the problem might be?
Søren Mexico
Mexico City
Posts 6,411
Instead of trying to get yourself killed, first of all read the manual, maybe you dont know to operate the deck. Second if the deck still is giving trouble, start with connecting a dim bulb tester, best, in connection with a variac, if you have current to the fuses and they dont blow, there is failure farther inside the deck, and the dim bulb will show you if it is so, then check the schematics and start looking for failures, not working mechanics or electric components.
If you dont have any knowledge about electronics, leave it to a repair shop, BG are not that complicated and a good audio technician should be able to get it working.
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, Feb 19 2013 8:21 AM
Oops, double post.
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, Feb 19 2013 8:22 AM
I agree.
It would be a bonus for us if you could post nice photos of the various parts of your Beogram!
There is a great fault-finding diagram in the service manual too.
Jacques
BeoWaff
Posts 25
BeoWaff replied on Wed, Feb 20 2013 10:57 AM
Ok thanks guys,
I will look through the diagram and start trouble shooting. I will get a dim bulb tested and see what that shows.
As far as the pictures I could probably post some on the weekend for you to look over.
Thanks again guys, I will keep you updated.
chartz
Burgundy, France
Posts 4,171
chartz replied on Sun, Mar 3 2013 7:23 PM
Any new developments then?
Jacques
Andrew
Melbourne, Australia
Posts 151
Andrew replied on Sun, Mar 3 2013 9:25 PM
Where in Australia are you Beowaff?
BeoWaff
Posts 25
BeoWaff replied on Mon, Mar 11 2013 3:15 AM
Hey guys,
No new developments at the moment, I have been busy with work so I haven't had the time to look into it further!
Andrew im in Melbourne.
I will keep you all updated.
Andrew
Posts 151
Andrew replied on Tue, Mar 12 2013 3:58 AM
I am based in Melbourne and know someone who can work on these units who knows his way around them pretty well, if you want his details shoot me a message.
Andrew
BeoWaff
Posts 25
BeoWaff replied on Mon, May 13 2013 8:45 AM
I just wanted to know if anyone knows someone in Melbourne who can look at an fix my Beogram? Any help would be really appreciated.
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Mon, May 13 2013 2:50 PM
Dillen:
Embarrassed
If a device consumes the same amount of power, then according to Ohm, the current will be reduced be a half, when the voltage doubles.
Roughly (as with AC current it's different)   P= U x I
Step1
Manchester, UK
Posts 1,268
Step1 replied on Mon, May 13 2013 2:55 PM
I wouldn't bother with the dim bulb if the fuse remains intact, as we know there is not a demand on current in this case. However have you know checked the other two fuses (one inside a yellow sleeve)? Looking is sometimes not enough so put a meter across both of them.
Now, just because you received an electric shock does not mean the neutral wire in the plug / cable is not loose! So you need to check that the transformer is energised.
After this, you need to check that the secondary of the transformer is energised with a voltmeter on a.c. volts, or skip that and check there is DC voltage of approximately 24V at the large transistor next to the motor - DO be carefull not to short any wires here!
There is also a second 6V supply too which you should check at this point.
Olly
Agent00soul
Posts 15
Shouldn't it be the other way 'round?
Beobuddy
Posts 3,972
Beobuddy replied on Wed, May 15 2013 4:19 PM
Agent00soul:
Indifferent Referring to?
BeoWaff
Posts 25
BeoWaff replied on Sat, Jun 15 2013 4:05 PM
Thank you, I will have a look and see how I go.
Finding the time is the key.
Big Smile
BeoWaff
Posts 25
BeoWaff replied on Tue, Jul 9 2013 3:46 AM
Ok so I have had someone look at it and has said that the transformer is going to need to be replaced, thats if i can source one??
Also the tone arm needs realignment and most moving parts need to be lubricated.
So my question is where do I get a Beogram 4000 5215 Power Transformer from, any ideas?
Thanks in advance.
Piaf
Victoria, British Columbia Canada
Posts 2,639
Piaf replied on Sat, Jul 20 2013 1:29 AM
Dillen:
Listen to Martin, I had to ship my Beogram 4000 all the way back to Martin in Denmark only to find out that I have the wrong fuse. My 4000 was delivered in Germany and although reset for 120v no one knew to change the fuse which kept blowing.
Jeff
Beogram 4000, Beogram 4002, Beogram 4004, Beogram 8000, Beogram 8002, Beogram 1602. Beogram 4500 CD player, B&O CDX player, Beocord 4500, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 8004, Beocord 9000, Beomaster 1000, Beomaster 1600, Beomaster 2400.2, Beomaster 2400.2, Beomaster 4400, Beomaster 4500, Beolab 5000, Beomaster 5000, BeoCenter 9000. BeoSound Century,  S-45.2, S-45.2, S-75, S-75, M-75, M-100, MC 120.2 speakers; B&O Illuminated Sign (with crown & red logo). B&O grey & black Illuminated Sign, B&O black Plexiglas dealer sign, B&O ash tray, B&O (Orrefors) dealer award vase,  B&O Beotime Clock. Navy blue B&O baseball cap, B&O T-shirt X2, B&O black ball point pen, B&O Retail Management Binder
Page 1 of 1 (36 items) | RSS
