i bought a beosystem 6500 a while ago and started repairing the beomaster 6500 amplifier because it doesn't turn on the 2 relays inside the device are activated when i put the power cord in the wall socket but nothing else happens is this normal for the device that the relays turn on or is the function some protection mode? if anyone had good advice on where to look for fault I would be grateful.
Sounds right.
