Hello
Is there anyway that I can get the sound from my tv coming out of my beocentre 7000 and its speakers?
Thanks for any advice
sarah
There's an AUX input on the Beocenter 7000. I believe you should be able to use this port to connect your TV to the Beocenter.
You could connect the TV headphones output to the AUX input on the Beocenter. You will have to use a correct cable that goes from 3.5mm headphone plug to DIN plug on the Beocenter. Maybe check with Steve from SoundsHeavenly. He should have cables like these on stock.
Thank you for your help - I will see if I can find the cable you mention.
Thanks again for you time - much appreciated :)
