Bought a Beogram 4004 in a beautifull condition!.
Seller told me the tone arm didn't move. I wonder why?
I hope it's not one of Martin's
Brengen & Ophalen
Difficult to tell but I don't think so.Mine are knotted twice.
Finally there is laughter Martin!
That tech doesn't know what he's doing. I use fishing tackle and it works perfectly.
But I glue the joint with Superglue, so the motor only skips a bit, and if you close one ear, you can't hear the skip at all.
Just be careful to not get Superglue on the plastic discs, otherwise you need to use a blowtorch to vaporize the excess glue!
Nah you've all got it wrong, old stockings are best :-P
Olly
