CD 3500 lid belt replace
trudys3
Posts 5
trudys3 Posted: Fri, Nov 20 2020 3:25 PM
Hi, does anyone know how to replace the lid belt on a CD 3500 . The lid will not open . Still plays the cd inside perfectly.  Regards Martin Mawhinney.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Nov 20 2020 3:28 PM
trudys3:
You have email.
trudys3
Posts 5
trudys3 replied on Fri, Nov 20 2020 4:33 PM
Hi, Dillen,  many thanks, trouble is the info is for the 3500 cassette player not the CD player.    Martin
Dillen
Posts 13,191
Dillen replied on Fri, Nov 20 2020 4:44 PM
trudys3:
Which is why I wrote "which is very similar if you concentrate on the lid motor part."
The only thing you need to skip is the part covering the replacing of the belts in the cassettedrive.
trudys3
Posts 5
trudys3 replied on Tue, Dec 8 2020 1:32 PM
I have re set up my beosystem 3500   All working but the remote won’t work the cd or the cassette functions, any answers Cheers Martin
Guy
Warwickshire
Posts 2,590
Guy replied on Tue, Dec 8 2020 2:24 PM
trudys3:
Have you checked that the DIN plugs have all 7 pins present?  If there are just 5 pins then then datalink commands cannot be sent to the CD or cassette.
Page 1 of 1 (6 items) | RSS
