Beocenter 2200 Tapedeck Power Issue
This post has 12 Replies | 0 Followers
Andreas
Vienna
Posts 72
Andreas Posted: Mon, Nov 23 2020 10:58 AM
Guten Tag dear community,
i'm working on a Beocenter 2200 in very nice condition which i was about to sell. Now i find that the tapedeck doesnt work at all. I changed all the Belts, but somehow the tapedeck motor is not turning and i do not hear any clicks even with a tape inside the deck. Voltage on Motor is like 100mV. Fuses are all intact. Only if i press 'next' i would hear a click comeing from the deck, but it would not go back unless i turn the whole unit off. Could it be that something has blown from the faulty belts or is there something i am missing ?
Thank you in advance, any help is very much appreciated.
Andreas
Vienna
Posts 72
Andreas replied on Thu, Nov 26 2020 1:15 PM
i could really need some help here, does anyone have an idea what the issue could be ? I have searched the whole forum without success.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Nov 26 2020 2:50 PM
Could be a missing power supply voltage.
Tape inserted.
Press TAPE
Press >   Does the motor start?
Press >> Does the motor start?
Andreas
Vienna
Posts 72
Andreas replied on Thu, Nov 26 2020 10:12 PM
No nothing, i printed out the schematic and i checked all the resistors and diodes around the Toshiba TC9143P. The IC goes through Pin 1-8 and 1-16 with multimeter, could there be a short at pin 8 ?
When tape button is pressed the light goes on but no click or motor running. If i press 'Next' the light for Next lights up and i hear a click and it gets stuck. I have to turn the whole thing off to reset. All the other tape related buttons do absolutely nothing. I also checked the tape insert switches and cleaned them.
Even when i turn the unit on the 'next' lights up and the relais clicks. Very strange...
Otherwise everything works fine
Andreas
Vienna
Posts 72
Andreas replied on Fri, Nov 27 2020 3:28 PM
Since the belt was stuck could there be a fuseable resistor for the tape motor which has blown ?
Dillen
Posts 13,191
Dillen replied on Fri, Nov 27 2020 4:07 PM
Can you take readings of the voltages on 3TR15 all three pins when the motor is supposed to run?
Andreas
Vienna
Posts 72
Andreas replied on Sat, Nov 28 2020 2:42 PM
on the motor itself its 170mV, by 3TR15 do you mean the 3 pins of TR15 ? both read 11,4V
Dillen
Posts 13,191
Dillen replied on Sat, Nov 28 2020 3:24 PM
3TR15 is TR15 on module 3.
Voltages on
B ?
E ?
C ?
with respect to ground.
Andreas
Vienna
Posts 72
Andreas replied on Sun, Nov 29 2020 8:33 PM
Hi Dillen,
E = 11.7V  C = 0.5V   B = 11V gradualy dropping
when presing play
E= 11.75V    C= 0,8V.  B=11V droppping
When measuring the motor turned for a second but couldnt recreate it anymore
Thank you for your help Martin, very much appreciated
Dillen
Posts 13,191
Dillen replied on Mon, Nov 30 2020 6:56 AM
Where do you connect your meters ground terminal, when you take the readings?
The emitter pin of 3TR15 is connected to ground so should ALWAYS be at 0V.
So either ground is missing here or you are measuring wrong.
Andreas
Vienna
Posts 72
Andreas replied on Mon, Nov 30 2020 4:39 PM
Sorry i think i used the wrong pin
E = 0v  C = 10,5v B = 0,6v
Dillen
Posts 13,191
Dillen replied on Mon, Nov 30 2020 8:55 PM
Hmm... that B voltage is just on the edge...
I would replace TR15 for a start. It's not a particularly critical type, something like a BC879 or similar darlington NPN would do fine.
Check also (or simply replace) the capacitors in the tape circuit. They are known to cause many problems. C7, C8, C9 C10...
Andreas
Vienna
Posts 72
Andreas replied on Tue, Dec 1 2020 8:47 AM
Ok i will try to replace them.
Thank you Martin for your effort and help
Page 1 of 1 (13 items) | RSS
