Radio on Beovision Eclipse
thorne
Posts 315
thorne Posted: Mon, Nov 30 2020 4:45 PM
Hi
a dumb question, I know, but how do I listen to radio stations on Beovision Eclipse?  Is it via TuneIn?
Problem with that is two fold
1. when I click on TuneIn on remote, I get audio message sayin it is not available in my country
2. I listen to BBC Radio 2 a lot, which isn’t available on TuneIn anyway
jvezina
Montreal, Canada
Posts 200
jvezina replied on Mon, Nov 30 2020 5:14 PM
Is the problem limited to the Eclipse ? Can you use Tunein on a computer or a mobile device ?
I am afraid that the solution will be to use a VPN to let Tunein believe that you are located in another country.
thorne
Posts 315
thorne replied on Mon, Nov 30 2020 6:40 PM
Yes, I can use TuneIn on my iPad.
And any thoughts about receiving BBC Radio 2a?
jvezina
Montreal, Canada
Posts 200
jvezina replied on Mon, Nov 30 2020 10:13 PM
In which country are you located ?
Is the country set on the Eclipse different from your country?
If you are located in the UK, BBC requires that the user uses their own app (to UK members, please correct me if I am wrong)) to force UK citizens to log-in.
Could you try on the B&O app (on mobile or tablet) to access the radio stations. No login is required.
Good luck,
Jean
Page 1 of 1 (4 items) | RSS
DigiCert Secured Site Seal
