Getting a Beogram 8002 up and running.....
This post has 10 Replies | 1 Follower
mfirst
Posts 29
mfirst Posted: Wed, Dec 2 2020 4:55 PM
longtime lurker and fan of B&O (for decades).....
Always loved the Beograms - but never had any records.....
A few years ago, I purchased a used Beogram 8002 (here in the US) - and while I plugged it in and it appears to be working.... I now want to give it to my college son who is getting into vinyl (yeah).
Few questions:
1) It needs a needle/cartridge - I have been searching and the prices are all over the place - I dont want anything cheap that will destroy his records, but some of the prices for NOS, etc are insane
2)  It has the standard B&O DIN connector - I have several DIN-RCA connectors for my other B&O stuff - but will those work to go to RCA and then hook up to the Phono or Aux of his system?
3)  Phono pre-amp?  I know nothing about the different types of phono stages......
thoughts?  advice?  suggestions?
thank you
-michael
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, Dec 2 2020 5:58 PM
1.
Contact Hans Henrik at pickupservice@outlook.dk
2. DIN is not a B&O standard. It's an international industry standard.
RCA is non-standard so don't use that.
3. B&Os cartridges are neither MC nor MM.
Connect the Beogram to a suitable Beomaster and you'll be fine.
mfirst
Posts 29
mfirst replied on Wed, Dec 2 2020 7:15 PM
Martin -
Thank you for your prompt reply.....
which of course, is raising more questions.....
As mentioned, I have several B&O kits that have the DIN (or whatever it is called on B&O) plugs (power/master link...never really understood the different - but that is a different topic?) that allow me to connect to the Aux of non-B&O stuff (i.e. headphone output from laptop to a BeoSound-1 on my best) - are you saying that whatever I plug into the back of the 8002 can not be plugged into anything other than a Beomaster or something Neo based?
...essentially, maybe the question is: can I plug the 8002 into something other than a B&O kit?
(are there needle cartridge options that are not B&O NOS, refurb, etc that are reasonably priced? (which I know is a relative term) - and that maybe can be purchased in the USA (the ebay stuff is $$$$$ - wow)
again, thank you
-michael
Dillen
Posts 13,191
Dillen replied on Wed, Dec 2 2020 8:06 PM
mfirst:
Martin -
Yes, if you do it right. (Separate chassis ground etc.) and have an input that accepts the level of the MMC.
mfirst:
(are there needle cartridge options that are not B&O NOS, refurb, etc that are reasonably priced? (which I know is a relative term) - and that maybe can be purchased in the USA (the ebay stuff is $$$ - wow)
Nothing but a B&O cartridge will fit directly.
That's how it was made.
sonavor
Texas, United States
Posts 3,732
sonavor replied on Thu, Dec 3 2020 12:28 AM
You can sometimes find a nice B&O cartridge on Ebay but you have to be cautious, ask a lot of questions and you really should be knowledgeable with B&O cartridges to make a purchase like that.
As Martin suggested, you will have much better success going through a B&O cartridge retipper/retorer like the pickup service he mentioned.
If you want a brand new cartridge then you can go the route of buying a Soundsmith cartridge.
I have done both.
Regarding what you connect the Beogram 8002 up to...
It was designed to connect to the phono input of a B&O preamplifier section which of course has a proper RIAA preamplifier in it.
You can connect to a non-B&O phono preamplifier section (either stand alone or part of an integrated amplifier) using RCA jacks but you will need an adapter. B&O originally made and provided such an adapter. My Beogram 8002 that I purchased in 1983 came with one. The adapter converted the DIN plug to two RCA jacks (left and right) as well as a single grounding wire to connect up to chassis ground of the non-B&O amplifier.
You can buy an adapter like that today from Soundsheavenly (see their advertisements on Beoworld).
Again, the adapter will break out the wiring you typically need for a non-B&O amplifier connection but that amplifier input must be a proper phono preamplifier section.
I hope that doesn't confuse the topic :-).
-sonavor
mfirst
Posts 29
mfirst replied on Thu, Dec 3 2020 2:57 PM
thank you... all so far very helpful..... my concern is mainly the cartridge....while I would love to get this up and working, I am not a hardcore audiophile and all of my music is now digital..... the costs for the cartridges and the limited options for them might be the rate limiting step here.
sonavor
Posts 3,732
sonavor replied on Thu, Dec 3 2020 3:34 PM
I would look for a rebuilt MMC-4 then. They are good performers and shouldn't be too costly.
I wouldn't buy one from Ebay that hasn't been restored. That series of phono cartridges from B&O are know to have suspension problems at this point in their life. The suspension is something a retipper place would have rebuilt so that is why it is best to go through them.
-sonavor
matador43
Posts 1,373
Good evening,
Is there a specific thread or any available document describing the "anatomy of a cartridge" and specially what actually is the suspension and why it is important?
sonavor
Posts 3,732
sonavor replied on Thu, Dec 3 2020 8:49 PM
matador43:
Good evening,
There were nice brochures from Bang & Olufsen that discussed their Moving Micro Cross system back when the cartridges were new (early 80's for the MMC-1 through 5).  I will have to look through my archives to see if I have any of those publications.
-sonavor
sonavor
Posts 3,732
sonavor replied on Thu, Dec 3 2020 8:55 PM
There are often B&O phono cartridge brochure documents on Ebay.
Here is one, and here is another.
I think I have those somewhere.
Those are not the MMC-1 through 5 series of cartridges though but there should be similar documents on that smaller size cartridge as well.
-sonavor
matador43
Posts 1,373
matador43 replied on Thu, Dec 3 2020 10:57 PM
Thank you Sonavor,
Should be interesting reading.
Page 1 of 1 (11 items) | RSS
DigiCert Secured Site Seal
