Hi all Beovision Experts,
I recently bought a Beovision Avant 55 (2016 - 1gen). In general I'm impressed with the quality and functionality, but I have noticed that the screen seems to be "bleeding" a light grey colour from some areas of the edges. On the attached photo you can see the "bleeding" from the top right corner when the TV is turned off and a flashlight is pointed towards the area. (similar "bleeding" is coming from other areas of the edge)
Without a flashlight it is less visible and when the TV is turned on you only notice it when the colour is close to black or a similar colour. (Couldn't figure out how to rotate the image - but I hope you still get the point. It is only the grey colour coming from the corner - the rest of the streaks and colour difference are reflections and crappy camera quality)
I read in another post about Avant 75/85 having a similar issue, but it should not affect the 55.
Any idea what this is? Is it likely to get worse and is there a fix?
Regards,
Soren
