Connecting Apple TV to Beovision with RCA
Lennart Hildeman
Scania
Posts 81
Silver Member
Lennart Hildeman Posted: Sun, Dec 6 2020 5:08 PM
Hi
I have a problem. The HD Video Converter that I got to connect my Apple TV to my Beovision does nothing. It is supposed to transmit the signals via the five RCA connectors, but doesn't. The really weird thing is that when i tried it out with just the two - left and right - I got picture, but no sound. Now I have bought three more RCA's and connected Pr, PB, and Y, and I get nothing. The setup that I used before, with the DVI converter, worked just fine, but I gave that to my daughter, and thought I would try the RCA instead. Bad idea, obviously. Is there some setting on Beo4 that I am missing, or is it just a bad idea?
Lennart Hildeman
Scania
Posts 81
Silver Member
It works perfectly after I changed it to a DVI converter. And I connected it to the computer, so I can now play media from that on the TV screen. Problems solved.
Page 1 of 1 (2 items) | RSS
DigiCert Secured Site Seal
