BeoVision Avant 55 transit brackets
This post has 5 Replies | 0 Followers
andydc
Posts 3
andydc Posted: Mon, Dec 7 2020 10:33 PM
I've purchased a second hand BeoVision Avant 55. It was delivered via a BEO store for myself to set up. Looking for advice please on how to remove transit brackets as I've no idea how they come off!!
 Brackets/supports as photo.
Champbeo
Posts 43
Champbeo replied on Mon, Dec 7 2020 11:27 PM
Pull straight down. Use a bit of force. That should do it.
Millemissen
Flensborg, Denmark
Posts 14,680
And don’t forget to remove the two screws for tightening up the speaker box.....if they are there (which is not always the case).
andydc
Posts 3
andydc replied on Tue, Dec 8 2020 4:54 PM
Thanks Champbeo, I'll give it a go when it's on the stand. Just waiting on a power lead!
andydc
Posts 3
andydc replied on Tue, Dec 8 2020 4:55 PM
Thanks MM, they're not there! Hope speakers will still be ok!
Gregg
Colorado USA
Posts 143
Gregg replied on Thu, Dec 17 2020 7:58 AM
I was utterly flummoxed by this too, and disassembled some of the housing on the TV to figure it out; and failed. As champ said, yank them down hard.
Page 1 of 1 (6 items) | RSS
